Chip I did press in a new bushing but with a new 3/4 shaft it was just to tight so I use a 3/4 reamer and now that new 3/4 shaft fits perfect and I believe has just enough rm for some oil.I wish that maybe I would have turn the OD on the old shaft pictured just a cleanup pass then see if it would fit.But I did not think of that plus I was thinking of making a new shaft but then I would need someone to mill a key slot.
Right now as I measure on the very end its .750 but as I move towards the shaft its at a slight taper but only .004 plus has ridges when moving the finger across it.
