Well, brazing was a no go. I had two torches (1 propane, 1 MAP) on it and after 20 minutes I managed to attach 1 glob of braze. I just can't generate enough heat unless I build some sort of oven out of fire bricks... and for that I need more fire bricks.
So lets talk about that sleeve. How thin can I get away with? I have about 0.160" total wall thickness on the shaft, and there is a key in it. I have attached a pic of what I am working with.
The large cone shaped piece is the one that needs repair. In this photo I have the piece pressed onto it's mating shaft (the end of which has the toothed pulley and dog clutch on the end) and mounted in the 4 jaw chuck of the monarch so that I could keep things concentric. When I took this picture, I had just finished cleaning up the surface.
Because the piece I am working on is pressed onto another shaft, it is hollow in the middle, so I don't have much material to remove... which is why I am wondering about minimum thickness on the sleeve.
In any case, I am going to grab some DOM tubing to try out. If anybody can advise me on minimum thickness, that would be appreciated. Currently the shaft is about 0.080" under size, so I am hoping that 0.040" wall thickness will do...
I also realized that this thing is going to be impossible to measure with a micrometer, so I need to make some go-no-go gauges? Or is there a simpler way?
