Repair Of My 15" Sheldon Lathe
Looking forward to doing those operations on new to me lathe. Any tips on set up? Thanks, Mike
I'll be glad to share my method of doing rotors and drums when that time comes. My not work for all, but will work for most.
Thanks, I'll keep an eye out for your post. I can envision doing it with some kind of arbor & bearing setup. No rush for sure. It will probably be year before I get around to giving it a try. Mike
Well, it's been a while since I've posted progress on my lathe. I had to move my lathe from storage for reasons beyond my control and put it in my driveway covered with a tarp for now. Meantime, I just about have the apron ready to go back together. Had to buy a couple of bronze bushings and machine them to replace the worn one's that needed replacing. Also had to buy some new clutch parts from Carlyle Johnson. Holy cow! $300 worth! Didn't want to buy stock in the company. But had to have them to get the apron back together. For some reason there are two missing parts that are needed for the clutches to operate properly. The only thing I can figure out that some one tried to work on the apron over the years and forgot to put the parts back in. I suspect they couldn't get them back in and toss them! Here some pictures on the progress.
DSCN3117.JPG DSCN3118.JPG DSCN3119.JPG DSCN3120.JPG DSCN3121.JPG DSCN3122.JPG
Had to make a fixture to hold two parts I'm making for the apron clutch controls. The mandrel/fixture allowed me to hold the parts in my super spacer so I could cut a square hole cross wise in two sleeves. There are two square holes at 180 degrees from each other. The corners do not have to be sharp, a 1/16" radius is acceptable. The sleeves are too thin to try to broach and I don't have a shaper, another tool on my wish lists.
Next step is putting the apron back together!
It's been nearly a year since I posted progress on the 15" Sheldon Lathe. I did post a thread last month on a tape measure I found in the boottom of the headstock while I was cleaning it. Here's some pictures of it.
Here's some pictures of the inside of the headstock before cleaning. I forgot to take pictures after cleaning. Used 4 cans of Brake Clean to get all of the gunk cleaned out and still had to wipe the rest out by hand. What a mess. Then on top of that, I over filled the headstock with oil. And still cleaning up the excess oil!!!
Got the electrics mounted and hooked up and running. I thanks H-M for the posting on the Huanyang Inverters in helping to get my settings just right. Still have some tweaking to do but it's pretty much done. Can't figure out why the pot works in reverse. Never had on do that. Even swapped a couple of leads. I think I need to swap the other two leads. Oh well, I can deal with that another day.
Next is getting the saddle refitted to the bed and so on.
Here is a couple of video clips of the lathe running. Ken
  • 20170402_165256_54661026778227.mp4
  • 20170402_165349_54713605039086.mp4
I worked on putting the tailstock back together for my 15" Sheldon lathe. I also cleaned and honed the bedways to remove dings, burrs, etc. so I can start the process of scraping and fitting the saddle to the bed. This bed is harden and ground and you can still see faint surface grinding marks in the worn areas of the ways. For a 57 year old lathe that is not bad! Here's a few pictures of my progress. I also posted a couple pictures of the apron rebuild I forgot to post last year. Ken
Really looking good. Did you make the ships wheel for the tail stock, or is that a factory part? Cheers, Mike
