- Nov 22, 2010
- 364
I Got a QC gear box for my 9" Model B to upgrade to model A... but I need to change the thread chart presently on the gear box...( wrong bed size)
I did a Logan last year and it posed only minor difficulty.. but the SBL drive screws appear to be made of KRYPTONITE... I ground the heads almost flush and was able to get a # 2 center to remove the heads but the studs refuse to be drilled or milled.
Is there a 3/32 bit that I could use to grind into the hole and grind out the stud without ruining the holes so I can install the new drive screws to attach the new chart after I repaint the Lathe ?
Plan "B" is to relocate the chart a "tad" and drill new holes
