- Dec 20, 2012
- 9,422
My tool envy syndrome now has acquired a top-of-the-drawer swiss-made clamping nut.
Who woulda' thunk that a nut could inspire such happiness and confidence! Rego-Fix - really, really good stuff.
Congrats!
Today I received the new Clamping nut from REGO-FIX. It is their latest: Hi-Q ERB32 for ER 32 collets. Just like the one that did NOT work for me, the new one has a friction bearing ring. UNLIKE the one that didn't work for me, the the lip of the friction bearing ring is ECCENTRIC and is marked with a dimple where you insert the tilted collet. Then the collet just snaps in. Then is closes down onto the threaded collet chuck. To get maximum gripping, REGO suggests using a torque wrench. For my LMS collet chuck hitched to a Grizzly 7X12, my pin-spanner works fine by hand. I tried it on some of the small diameters (like 0.083"), and I could not make the rod budge in the collet no matter how hard I tried.
Happy ending. My tool envy syndrome now has acquired a top-of-the-drawer swiss-made clamping nut.
REGO has some info on it on their web site.Would someone describe how to use a torque wrench on the collet? Is there a special torque wrench for it? How to set up a standard one wo work?
I thought about making a deep socket adapter with a 1/2 inch square on the bottom for a torque wrench. Is this tool available? Needs to be deep enough for the stick out of the tool.
Ken, you might be surprised at the torque specs for ER collets. The larger ER collet sizes call for some hefty pulls to be at the recommended torque.I just tighten it well enough so when I go to loosen it I'd need to exert some force to release the nut. practice makes perfect.
I don't doubt that Bob , if the proper torque wrench wasn't so out of reach for us hobbyists I wouldn't hesitate to get one, I happen to have a strong grip in my left hand lol.Ken, you might be surprised at the torque specs for ER collets. The larger ER collet sizes call for some hefty pulls to be at the recommended torque.
Torque is a pretty simple thing to test roughly, without specialized torque wrenches, to get in the ball park. Torque is measured in foot/pounds, or in newton/meters. Using the imperial system, if you are pulling from one foot distance from the spindle center line, with one pound of force, then you are placing one foot pound of torque on the nut. 40 pounds of pull at one foot is 40 foot pounds. 80 pounds at 6 inches is 40 foot pounds. Simple arithmetic. So, take the wrench you are using for tightening your collets and drill a hole in it near the end of the handle. Measure how far that is from the spindle center line. Get something simple like a spring fish scale, hook it in the new wrench hole and pull on the handle hard enough to reach the torque you are looking for, using math to find the needed pull. You would not need to do this every time, just do it to get a good feel for the actual recommended tightening force. You could also put a square hole in the handle and use an actual square drive torque wrench to tighten the collet, and that works. Kind of awkward, and requires doing the math for the compound torque of the compounded wrenches. I'm sure there are other ideas. I do not use ER collets, so far, but I know for sure that I would not buy a dedicated torque wrench for them if I did have them.I don't doubt that Bob , if the proper torque wrench wasn't so out of reach for us hobbyists I wouldn't hesitate to get one, I happen to have a strong grip in my left hand lol.
I do admit when I first got the ER chuck I underestimated the necessary clamping force but I blame some of it on the cheap ER nut that came with it.
