- May 6, 2016
- 31
I'm a newbie to machining but after about a year of fooling around I now can confidently place an ER 32 collet into the clamping nut and screw it into the collet chuck on my 7X12. And I've made some nice small diameter things of 304 SS.
BUT: all of a sudden I got a severe attack of tool envy and bought a Swiss made REGO-FIX clamping nut really cheap at a garage sale.
PROBLEM: unlike mt humble Chinese made collet nut, the REGO has no eccentric ridge that allows me to wiggle the collet into the clamp before setting it into the collet chuck.
HOW DOES THE REGO-FIX CLAMP WORK?
In the first pic below, you can see the familiar eccentric ring in my usual clamping nut. No problem.
In the second pic, the Rego-fix, there is no such ring. The only way I figure to insert the collet is to insert the collet into the chuck first and then tighten down the nut over it. That is a really (really, really!) tight fit, so I haven't done it. I don't want to apply full force cause I'm afraid that this is not the right way. Then again, the REGO-FIX may work in an entirely different way. The models currently available are "Hi-Q", but mine is an "HK".
ANY SUGGESTIONS?
ANY SUGGESTIONS?
