4
4GSR
Forum Guest
Register Today
i'm seeing the same thing Ken
the base casting will need fill up work as well, i surmise.
Yeah, Agree. I'm visualizing two worn grooves in the base casting about the width of the thin jaw rail. If that's the case, I would find some one with shaper and have them shape two flat grooves about 1/2" wide and just deep enough to accept a piece of 1/8" x 1/2" brass flat bar and compensate for the machining of the jaw. An bolt the brass flat bar in with some small brass flat head screws spaced about 1" apart on each end. Second though may not have enough room to do that on one end. Be no problem to glue down and use the jaw as a holddown to get the brass shims set in place.
