Yeah, the tight area is probably harden grease.
To get the table off, you must remove the two 1/4" socket head cap screws located down in the tee slots of the table top. Once removed, gently pry the table off. Palmgren did not press fit anything, so it shouldn't take much to get it removed. Oh, I forgot, remove the two knurled screws and the clamp shoes that locks the table down before removing the table. Once that is done, everything else comes apart easily. All of the pins that hole the handwheels onto the shafts are straight drive pins, not tapered.
When you go back together, use a waylube on the worm gear where it rides on the internal stud. On the worm and worn gear, use a grease with moly-disulfate in it. Before putting it back together, check the assembled height for correct clearance of the table to the housing. It should have only about .002-.005" clearance. If more than that, face off a little on the worm gear and try again. I used my surface grinder to do this as well as on the table top, too.
Nice Rebuild.
I've never been able to understand the advantage, in the Palmgren design, of having the x-y cross slides below the rotary table vs just mounting a standard rotary table to the x-y mill table?
Nice Rebuild.
I also have a Palmgren 8". I've never been able to understand the advantage, in the Palmgren design, of having the x-y cross slides below the rotary table vs just mounting a standard rotary table to the x-y mill table? I can see the advantage to having the x-y slides above the rotary table, as it would allow one to easily offset the axis of rotation, to make non circular shapes. Am I missing something?
Palmgren made a series of rotary tables with the X-Y slides for the packaging industry. Rather than being used on a machine tool they were mounted on a portable stand with a labeling machine attached to the table. The table could be turned or moved in the X or Y direction to accurately align labels to fast moving packages packages. Where I worked we used them in several applications. Some packages had plastic covers with a raised edge slightly larger than the label itself to keep the label from being damaged. The labeling machine on the rotary table could place the labels within the raised boarders within a few thousandths of an inch at a rate of several hundred packages per minute. Some had a hard life. Over the years they would go from below freezing temperatures in production rooms to 140+* degree caustic wash downs on a daily basis.
I currently have 2 that were retired from production in my shop. Since they were used for stationary positioning rather than being moved for each operation they are in remarkably good condition.
I have uploaded a 1959 Palmgren Catalog for those that want to play along.
http://www.hobby-machinist.com/resources/palmgren-catalog-207-dated-11-1959.3129/
