- Dec 23, 2020
- 59
To aid with cleaning the lathe I'm refurbishing, I picked up a 20 gallon parts washer. I realized I could buy one, use it, & then resell it when done for most of what I paid for it and it will speed the process. Anyway, most of the parts washer solutions I'm seeing are water based & I'm thinking it's not a good idea to use those with so much bare metal.
What have you guys who restore machinery found that works well to clean them and is cost effective? If you use a water based, do you simply dry and then oil the bare metal to keep from getting flash rust? I'm in the Houston TX area which is very high humidity so flash rust is an issue if not careful.
