- Jan 5, 2014
- 995
So, I pulled some old steel, galvanized well pipe out of my well last year and replaced it with plastic. I couldn't find my way to throw it away. It was very corroded at the lower end but I have about 100 Ft. of good stuff. I thought it might make good legs or something for some future projects. Anyway, I tossed a piece on my lathe today and ran an insert across a 32" section of it. I ran at 550 RPM and the diameter was about 1.6" when done. The depth of cut was about 23 mils, and the feed rate was 4mils/turn. I just pulled the feed/speed out of the air. The insert was a cheep one from Grizzly from a kit of 6 tools they threw in with the lathe. The finish was really great but the screeching was terrible! I tried cutting oil and that quieted it down but the smoke was worse so I just put on ear plugs and muffs and cut the rest dry. On the plus side, I found that my tail stock was pretty well aligned. I've never cut anything that long before. I got 1.601 at the tailstock end and 1.600 at the headstock end measured with calipers. I was pleasantly surprised. Not bad for a Grizzly that I have not spent much time tuning up. Also, the 1.600" was sheer luck as I wasn't shooting any particular diameter. The stars were aligned or something. The center was about 6 mils bigger because I was not using a follow rest but that I expected from the flexing.
Anyone know what kind of steel might be in galvanized pipe from the early 1990's? Do I need to worry about the fumes if the galv. metal gets hot when cutting? How do I stop the screeching?
On another note, how do I go about working an 8 Foot piece if the stuff? It does fit through my head-stock.
