- Jan 20, 2018
- 5,812
I had some old ABS drain tees with short stubs of pipe to go to the trash, when I realized they had potential. I cut a couple of the stubs off, about 3 in. long, and split them once lengthwise. Then I put them on a s/s plate in the toaster oven at about 225° F. When they started to soften, I spread them out and put them back in to flatten completely. Once fully softened I pulled them out with the plate and pressed them with a heavy piece of steel, allowing them to cool. The 3" pipe unrolls to a little over 10" flat, and the thickness is about .260 in.
![20220426_142412[1].jpg 20220426_142412[1].jpg](https://www.hobby-machinist.com/data/attachments/362/362480-f7681f2dc19b82227cf59eb96b5c6e3a.jpg)
ABS is an excellent material to work with, good strength, impact resistance and rigidity. Most importantly, it can be glued. I can see gluing these up to make thicker stock.
