I am having one problem with the drawbar collet closer I built. The needle thrust bearings make it smooth and easy to tighten the work in the collet. However, they also have much less static friction, so they tend to let the setup loosen a bit each time the spindle is started, due to the inertia at rest of the hand wheel/drawbar assembly. I also suppose that the opposite happens when I shut down the spindle, but it must be to a lesser degree. I intuitively understood this issue when I when I designed and built the collet closer assembly, and lightened the hand wheel, which also improved the grip of it. At the time, I was more worried about it auto-tightening itself rather than coming loose. As it is now, the hand wheel needs to be tightened after every couple of starts or the drawbar goes loose on the collet. I am considering ideas to improve the situation. My ideas so far are further reducing the rotating mass of the hand wheel and/or perhaps making some sort of connection that would need to be manually released to loosen the drawbar. Well, further thinking while writing this made me realize that such a catch would probably need to related to the collet threads, which seems unlikely. Perhaps there is some option at the left end of the spindle to lock (and release) the hand wheel assembly to the spindle. It works very well like it is, but is annoying to have to keep tightening it. If anybody builds one, consider the issue in advance.
