There really isn't any good reason for anyone to have used asbestos insulated wire in a motor. One that got hot enough to need it would be on it's way to scrap anyway.
Well well, 9 yrs goes by and my 10F motor just hummed - no start. I took it apart and got the proper cap from Grainger. Mine has cast iron end housings, and different bearings. Mine are 15 X 35 X 12.3 mm SKF bearings - no matches found, but I cleaned in carb cleaner overnight, removed the shield and found a felt seal ring. Inspection of the races showed no issues although the cage rubbed a little. How about that, it has run since 4-44 per the date on the CAP. The felt rings were oiled with a drop of 20-40 synthetic, and packed the bearing with SCH100 Mobil synthetic bearing grease. The centrifugal portion of the switch worked smoothly but lubed the shaft with some Krytox 205 as it does not dry out. The switch was sanded and cleaned, then "adjusted" to ensure good contact when stationary. The biggest challenge, other than remembering just how it came apart, was ensuring the wire insulation was not broken. It is now back in the lathe and running again. WoW - - 79 yrs old and finally the cap was dead. If any of you have bad bearings, there are some 15X35X11 and X13 available sealed both sides for alternators. I was on the verge of using the 11mm width and adding some spacer rings to ensure the end float was still in spec. I assume the housings were cast iron as aluminum was in short supply in war time. Also, one 13mm and one 11mm might also work for the total length with no issues. BTW: Alternator bearings are sealed with sides and live a really long time with the grease they use.Hello to All;
I am in the process of refurbishing an old Atlas 1/2 hp motor for a 10F lathe. It came off an Atlas band saw and was full of sawdust and old oil/grease. I can't get the case apart after removing the 4 steel rods holding the case together. Has anyone done this before, and will I damage the motor by disassembling it? It was tested beforehand and did run, although it was slow starting...I suspected that the starting capacitor would need replacing. Any suggestions would be appreciated.
Lou O.
