Reamer vs. End Mill Hole Quality?
ShagDog
Jun 11, 2020
354
A part needs a 5/16" reamed hole about 1.25" deep. The hole diameter is not crucial within a couple of thou. I don't have a reamer that size, but I do have a 5/16" carbide 2 flute end mill. Will the quality of the hole be as good, better, or not as good as if done with a quality reamer?
If the size is not critical , drill it undersize and follow with a 5/16 drill . The end mill would cut oversize most likely .
Oversize from the end mill is fine. I just want a really nice quality finish, which per my understanding a reamer will provide.
Reamers are good....
Especially if you want an accurately sized, well finished hole.
What's the application?
John
John
Crankshaft bore on flywheel for I.C. Model engine. I can turn the crankshaft to fit the bore. Might just have to break down and buy a US made reamer
Try your endmill vs. a drill on a piece of scrap then decide if you need to invest in a reamer
I did the bore for the 1/2" crankshaft support with a 1/2" 4 flute carbide end mill in aluminum and it turned out fine. I just can't picture a drill doing a comparable job to a reamer or end mill.
I've achieved some nice finished drilled holes, but only after drilling a size under first, and using a nice fresh drill for the final size
But a reamer is best
