- Feb 2, 2014
- 112
I got a new tread tap to day, an tried ut the reamer. It worked well, but the cutting steel from a broken tap was to weak. I get four cuts ready, but I had to grind the tool tee times, so I stopped. I have to find a hss tool that fit in the 5,5 mm hole or make a square hole and put some Square tool in. My be with a bigger hole? May be I can harden the steel? Since it is from the other end of the treating bit? I suppose it i not hardened there?I could may be use a 6 mm square lathe bit HSS.?
