- Sep 22, 2010
- 7,220
Since a couple others commented on the 4" X 36" Belt and Disc Sander, I wanted to add my two cents, also. Now, I don't own it, but I went to HF a couple days ago for a couple small things and checked out this sander, along with everything else in the place, as I always do when I'm there. They have it on sale right now for $59.99.
Well, I wasn't impressed. The biggest negative I saw was in regard to the table for the sanding disc. It is mounted with a single rod that fits into a hole in the casting which, in turn, is secured by a single bolt that holds against a milled flat on the rod. The rod/hole fitment was sloppy to say the least. On the store display, the bolt was secured tightly and, because of the slop fit, the table was nowhere near square to the sanding disc. It's just not a good setup. It may be OK for free handed sanding, but that's about it I would say. I wouldn't expect accuracy with it.
There are 3 videos to repair this machine:
I have just bought this machine for $59.99 on sale now. I intend to replace the rollers, fix the table, and get a more powerful motor for it.
