The Good:
I have the 13 x 40 lathe, and it has been good, except that the change gear box leaks, and I havn't been able to locate the leak and fix it (in spite of removing and dissasembling it). I think I am going to take it back off and grease the gears and call it good. If I were going to get one of these lathes today, I would get one that doesnt have the sealed change gear box (since it didn't stay sealed anyway). Overall it's been a good machine and made a lot of chips.
Engine Hoist, grinder stand, engine stand, floor jack, Hand tools, abrasives, dog beds, bench with casti iron ends and wood slats, sandblasting cabinet, parts washer, cement mixer, Porta power, casters, 1 hp electric motor for my drill press.
The Bad:
Air tools in general. I have written them off for air tools. I got an air crimper, longboard sander and air hacksaw that didn't work right out of the box. I've had two of thier air niblers and on both of them the pintle broke, well before I think it should have. I will no longer buy air tools there. I also bought a hydraulic gear puller that crapped out as well.
The Ugly:
The motor went out on the drill press, but that was after a number of years of use. Throw away the chuck that it comes with and buy a Jacobs. The belt changing mechanism won't stay tight, so I drive a wooden wedge into it to keep the belt from loosening when in use. I just don't like the whole belt changing mess, I'm going to do something about it (some day).
The 12" disc sander, which I bought as a display unit and got a great deal on has been a great addition to the shop, I use it all the time. That being said, when it was new, I had to remove the sanding disk and face it, as it was warped about .040. That requied that I rebalance it. If you don't have the means to face a 12" diameter cast iron disk, I would pass on this one. Oh, and don't bother with HFs disks. They last not time and are murder to get off the plate. Get some good quality disks like 3M. They last 10 times longer and don't have quite the mess to scrape off the wheel (they are also much more expensive, but when you spend 45 minutes changing a disk because you have to scrape ALL the old one off, the price seems worth it).
The Baldor look alike carbide grinder. Again, this has been a good tool and I got a great deal on it, but I had to debur the tables to get them to move, and they still arn't smooth. I also had to weld up the aluminum hubs and re-cut them to get them to properly center the wheels, and then ballance the wheels. The wheels it comes with are so bad you may have to put a bolt and nut in one of the extra holes to get it ballanced. I have one o the original wheels on one side that I ballanced and a diamond wheel on the other side that required no ballancing and it runs smooth, now.
