Nope, pre-stamp. The finish appears complete and polished, but I haven't tested it for being heat-treated yet. It's either pre-hardening and not yet stamped, or the info would be stamped on the rim of the inner race. At a guess.No numbers on it?
Unfortunately, the subtended arc is so small that I would suspect the precision of the results would be close to the noise.Do you have an outside mic that you could measure it ? It should measure the same at different spots if a sphere
This. Former employment we had to make such to gauge radii outside the range of available gauges for shop personnel to use. As to the effectiveness the customer found product to be in tolerance and accepted it.You can machine a disc with a 4 3/4" hole in it, then split the disc. To save you time just assume the contour on the OD is spherical. That type of bearing is used in pillow blocks in a spherical cavity. The shape needs to be spherical in order for pillow blocks to self align.
