- Nov 19, 2014
- 991
Only a three link rear end is allowed in this class, but you can pretty much configure it any way you want, the first pic is looking right to left, you can see the top link and the attachment of the J bar. Next pic, examples of lower links top; a simple turnbuckle with spherical bearings, mid; an old style swing arm with spherical bearings, this type needs one end disconnected to make any adjustments, bottom; a swing arm with an adjustable end, we are converting this car from the top one to the bottom. Third pic, my son Bryan making final adjustments to the suspension using a plumb bob and tape to locate the rear axel, the devil is in the details, it took him all afternoon to set the axel where he wanted it, last pic is the finished suspension, swing arm lower with the spring in front of the axel and the shock behind, the device where the spring is supposed to be is a spring slider, a linear bearing that eliminates a shock absorber, and is adjustable for spring pre-load and ride highth. By using a longer swing arm on the right side and a shorter one on the left and letting the body lean over in the turn we are inducing rear steer, similar to an articulated loader or forklift. This is supposed to help you get through the turn faster, it's all about chasing the latest fad.
