- Jun 24, 2021
- 81
Hi guys, I have a milling machine with an R8 spindle and have been using round collets to hold endmills. I always wondered about the rigidity of these things but never saw the issue addressed anywhere till I saw a video that said a collet should only have .003 clearance between the endmill shank and the hole in the collet,otherwise the "finger" of the collet will only grip the shank with the very tip of the finger. This makes sense to me, but do you guys check this with every collet you use? I checked a 1/2" endmill in a 1/2" collet and had a nice fit. Then I checked a 3/8 endmill in a 3/8 collet and there was over .020 thousandths clearance and sloppy as all get-out. Does this mean my collet is junk? What do you guys do? Hope someone can enlighten me on this.
