RJSakowski H-M Supporter - Gold Member H-M Supporter Gold Member Apr 27, 2020 #11 Tozguy said: What do you mean by 'heavy loads'? Click to expand... High material removal rates. Using roughing end mills with large depth and width of cut. High helix end mills are more prone to pulling out.
R rzw0wr Registered Registered May 2, 2020 #12 Thanks for all of your replies. I think I am not tightening it enough. Thanks, Dale
T Tozguy Active User H-M Supporter Gold Member May 3, 2020 #13 Keeping the bore of the collet squeaky clean is important but a light smear of grease on the outside of the collet helps too.
R rzw0wr Registered Registered May 10, 2020 #15 I just bit the bullet and ordered an 11 piece set of Lyndex.
