Quick change toolpost question
Sometimes I have a problem with the tool post turning as I try to tighten the nut after repositioning so I made a short shaft that screws into the hole in question . Then when I tighten it down I have something to hold on to.
I removed that little spring loaded pin from underneath as I found it a pain locking up the rotation when I wanted it to turn.
I also use a thin brown paper shim between the solid mount and bottom of the AXA tool post.
Another mod was using a much finer thread on the tool post bolt.
I will now use a shim under the top nut as well as sometimes it will turn slightly when tightening it. Thanks Tozguy.
