Issue #1: Hot working.
Take a think piece of wire 1" long, make a perfect circle, measure the diameter.
Take the same piece of wire, heat it up and while still hot, make a perfect circle. This one is bigger in diameter.
No need to argue this. It's been solved a million times in basic text books in mechanical engineering. And by the way, when I press pulleys onto shafts, the first thing I do is put the shaft in the freezer and the pulley in the toaster oven and sweat them together.
Issue #2: Heat Treating.
I was wrong. I looked at the reference books and they show no difference in size pre and post heat treating. I do recall reading there is a small change ranging from micro-meters to nano-meters (x10[SUP]-6[/SUP] and x10[SUP]-9[/SUP]) that for all practical purposes is zero. The effect is about the same dimensional changes as from bluing or black oxide. There may be other effects such as scale build-up and sag. Scale build-up is controlled by using gaseous or vacuum chambers. Sag is prevented by using pyrometers and not color charts to reach the critical temperature.
Ray
- - - Updated - - -
There's really no guess work. I very well remember this problem in my beginning physics classes. Irregular structure or not, atomic forces need a place to push. Those forces find nothing to push against inside an empty hole thus, each atom therefore pushes against the ones next to it. At the very border of the inner circle, you can image it being a wire of negligible thickness or infinitely thin. As in the case of the wire example below, it stretches it's length and increases in diameter. This problem is very, very solved -by people many, many years ago.
Ray
- - - Updated - - -
By the way guys, I'm not just posting my theory on what happens to a hole when heated-up... My first instinct would be to think the same thing but, no kidding, this is a classic textbook physics problem that most engineers and all physics students had to solve or was exposed to at one time. This is not theory, it's a physical fact.
Ray
Ray
This is a very interesting mental exercise! My initial guess was that the hole gets bigger upon expansion, I can see the argument both ways but I am still with Ray C on this.
- - - Updated - - -
Ray
Plus the symmetry or lack of it affects the direction of change in the grain size and structure, which the root cause of all this. Things that grow in one direction canshrink in another. That's why this whole thing is a bit of guesswork at first, anyway.
- - - Updated - - -
Ray
