- Nov 27, 2012
- 7,912
I bought a True Line 88 to see if it does the job and when I have the time, I'll install it and review it for you guys here.
Awesome, looking foward to it even though I don't have a round column. Take your time but hurry up!
My column is trammed with precision shim stock and onion skin (precision paper shim stock). It is 0.0005" high in the front of the table and zero in all other directions. It took two days, two days, to get it there. I used a torque wrench set to 35 lb/ft on each column bolt to be sure that didn't mess things up and when I got the final shimming done, I loosened and re-torqued the bolts to be sure nothing changed. I admit that I haven't looked at it since so it may have changed. I'll have to go re-check it soon.
Haha, I think it took me like 4 days! 1 whole day to figure out how to support the head & column to insert & change the shims everytime. I used precision shim stock also. I got mine down to .0007" (low in the front) but I can manipulate it depending how much I tighten the head locks. Mainly it's the top one that affects it.
I just retrammed last week (tilt). Been years since put those shims in there and the nod is still the same from what I remember. My guess is yours hasn't moved either. I'm going to reshim again though, making sure the column gib is adjusted nicely first.
