- Apr 19, 2018
- 65
I'll try and keep this short but a little back ground. I have one of the older HF round column mill/drills. ( model 24976)I know it has it's limitations but I am trying to get it to be as good as it can be. Finally got the spindle/quill re worked, and a simple DRO to have something for measruing the Z ( it had nothing) so it's time to dial it in and get everything square.
The other night I cut some shims and was just going to get started and see just how hard or fussy it was going to be and to my surprise it was much closer than I expected.
So I started trying to make it better. Ended up chasing the indicator around for more than two hours and a couple dozen different shim combinations. Made it a lot worse at times but the best I could get was within about .003-.004. I was using an indicator and a new disc brake rotor placed on the table and sweeping about a 10.5 inch circle. Question is; should I expect it to get much better with this machine? I was working alternately on both the side to side and the front to back and was kind of chasing it in and out a lot.... Right now fairly well snugged up it's off about 3 and half thousands on the Y and about 2 thousands on the X. It that as good as it gets or do I need to drink a big cup or patients and go back at it?
Thanks-
Thanks-
