- Feb 27, 2014
- 2,286
I want to make a disk 4" in diameter and 1/2" thick out of aluminum. Then I want to press 10 1/4" diameter drill rod into equally spaced holes. In order to ensure the smoothest surface, I can think of a few possibilities and would like any suggestions
1. Cut the drill rod slightly long by 5 or 10 thousands then put chuck on lathe and face both sides
a. Should I worry that the cutting tool will be cutting both aluminum and steel? it would be an interrupted cut until the drill rod was flush with the aluminum
2. Same as above but use the belt grinder to bring the drill rod down to the surface of the disk.
a. would have to follow up with some hand sanding to get a decent surface finish
3. use the lathe to part off each of the 10 drill rod pieces so they will be flush on both sides when pressed in.
a. Still would likely need to sand each face a little to ensure perfectly smooth.
Open to other ideas or suggestions.
THIS is what I am making but using aluminum instead of 3d printing in PLA
