Thanks! Much appreciate your time and input. Off to the hardware store I go!If you round the end of the 5/8s to the shape of the dimple it will be fine. the OEMs are out of the box square.
I have another question, but no hurry. I am wondering what the diameter of the un-threaded hole is that is next to the threaded hole?If you round the end of the 5/8s to the shape of the dimple it will be fine. the OEMs are out of the box square.
Thanks so much again!.755 is what I'm showing
Keep the dimple, just smooth it's sides is what I meant.
I didn't say I removed the dimple, I actually cleaned and recessed that area also to contain the bolt properly(an actual recess,not an uneven rough casting). If the area isn't smooth then every time you make a turn with the bolt the movement is uneven and inaccurate. I also made sure the bottom of the bolt was flat. That way when you adjust the bolt isn't jumping from high spots to low spots. Also your floor should be reasonably smooth.I would think if you smoothed out the dimple it would help the bolt find it's level better.
