- Dec 31, 2010
- 937
I once enlarged a hole using a fly cutter by the method discussed earlier, adjusting the cutting bit out incrementally until reaching the proper diameter. If no mill is available using an angle plate bolted securely to the cross slide. You may have to adjust the work several times to get it centered then bolt as rigidly as you can.
Good luck
Ray
Good luck
Ray
