- Dec 3, 2018
- 9
I need to bore a larger hole in a table saw trunnion from about 16mm to 25mm to accept a bearing. For the life of me I can't think of a way to drill this hole. If I could chuck it up on my metal lathe --> easy done, however, the piece is too wide and won't be able to freely turn. I could reverse everything and mount the piece on my compound rest with a right angle attachment and put a boring bar in the chuck but that won't work (unless I had the exact size drill bit)
I don't have a mill but have just about every other machine and tool. I don't have the exact size drill bit to put in my drill press and even if I did I'm questioning the results. My mind has hit a roadblock and I can't figure out how to do this anyone have any suggestions? There has to be a creative solution to this or am I stuck just having to get a large drill bit and go at it on a drill press or reverse everything on the lathe?
Much thanks!
Much thanks!
