- Aug 26, 2013
- 1,061
Bear with me for a moment on yet another tramming question.
On a square column mill drill the following parameters are fixed (unless you have a really big mill to re-machine stuff).
1. the angle between the x and Y Axis. Ideally it's exactly 90 degrees but it's most likely out by some small amount.
2. The relationship of the head/spindle to the column in the y axis is fixed (no nod). Ideally it's exactly parallel, but it's most likely out by some small amount.
The adjustable parameters are:
1. the angle between the column and the y axis
2. the angle between the column and the x axis
3. the angle between the column and head/spindle
For #1 you can use the standard tram method of sweeping the table and then shim the base of the column accordingly.
What I'm stuck on is #2 and #3.
To me the correct method would be to use a cylindrical square or precision angle plate to adjust the column in the x axis relative to the table, and then use the standard tramming method to sweep the table to adjust the head/spindle true to the table and column (in the x axis) at the same time.
Does that make sense? How is everyone else doing it?
