- Jun 7, 2013
- 10,452
If the thread to be cut is a factor of the lead screw, you can open the half nuts and restart the thread at any point where the half nuts will close; as an example, if you had a 4 TPI lead screw, you can cut 4,8,16, & 32 TPI without having a thread dial, otherwise you can simply back up the tool by engaging reverse back to the starting point, OR you can stop at the end of the thread, disengage the half nuts and measure back in full 1" distances and reengage the half nuts before starting the lathe spindle, that is what the thread dial does.
