I am missing one of the two hand wheel studs? on my 15" Colchester.
The picture is close to mine, the 10-24 cap screw is in it's recessed hole.
Here is what I am thinking,
Chuck up 1/2" stock and drill to size for clearance. Counter bore the end then set up the compound to cut the taper, part it off.
I can hand file the parted end.
Does this order of operations make the most sense?
I know it's a simple project but I don't want to miss the obvious. I won't be able to grab it once the taper is cut.
Thanks,
Thanks,
