I chunk here is gone but might as well pick it up a bit. :biggrin:
Had an exciting day today as I rented a nice little forklift (I gotta get me one of those things. :thumbzup
and moved the machines from the back of my truck kind of into my garage/shop space. "Kind of?", you may ask. Well, therein is the story. After taking delivery of the forklift I moved some things around in order to reach three palettes of brick that are in
the back of my space (long story not real important). Got everything out of the way, great, then hopped on and fired up the forklift. As I was approaching the garage door a little detail came to my attention that would turn this in to more of a job than I had figured on - the forklift was too tall to get into the garage! Most of you are probably saying, "Well yeah, duh!" but it's been a long time since I was last around one so....
Anyway, things got a little interesting. I ended up using the 40' tow strap that I keep in my truck to wrap around the base of each palette then pull my truck up to the garage door opening and drag the palette flush with the door. The forklift worked perfectly from that point on. Getting the grinder off the truck wasn't too bad as it was towards the back of the bed anyway. I strategically wrapped the same tow strap securely around the grinder and slick as a whistle it was done. Have I mentioned that I love my tow strap? :biggrin: The shaper was a bit more problematic as it was right up next to the cab in a full length bed. I ended up using the forklift from the side, and once again creatively arranged the tow strap around the shaper, then lifted the shaper. With the tailgate down I drove the truck out from underneath the shaper and all was good.
There was a little "excitement" as I went to put the shaper in the mouth of the garage. Running lengthwise to the garage face the parking lot is kind of a shallow "V" shape for directing drainage (or just a poor job of laying of asphalt) which required me to run downhill into the "V". I didn't have the shaper high enough and the edge caught on the rise of the "V". This pulled one side of the tow strap off of it's fork causing the shaper to drop 6" or so. One corner hit first and then it did that slow-motion "rocking" thing where you don't know if it'll go over on it's side or not. A couple of skipped heartbeats later is settled down without any damage that I could discern. Re-did the rigging and set it down just inside the garage door.
Now I have a little time to acquire a shop lift to further move things around. Hopefully I'll have some time tomorrow to go over them a bit better now.
-Ron
