If you can talk someone out of their copy (not likely, definitely not mine), try to find a Jorgensen blue book. They have a cd now, I believe, instead. Also online, they have a virtual copy:
http://www.emjmetals.com/Products.aspx?ptype=products&type=pbbk
As far as all 300 series stainless machining the same, that would be quite wrong. Ease of machining in the 300 goes to 303. But it's not the most chemical resistant, I believe that goes to 316 in the most common forms. Bad for welding, unless you use 316L, with the "L" this time not signifying lead, but "low carbon" which makes it better for welding. There are a number of 300 series stainless materials, but not all are available in all forms. Some just bar, and some only in sheet products.
