If they do not go low enough, then you need holders for LARGER lathe bits. The wider slot also allows a lower mounting height. The oversize holders usually have "XL" as a suffix to the part number. By the way, 12.7mm is 1/2 inch.ya im going to go with the phase 2 on amazon its just under 200. I was asking about the tool holders.... on which size to get seems I read somewhere that the 1/2' toolholders couldn't get low enough on my lathe so im thinking 12mm is about 1/2" and I should prbly go with the 10MM. ???
