As usual, slow and well behind the curve
... That's my normal state of affairs.
I have both a Craftsman 12X36 (101.27440) and a 9X19 Grizzly. (G1550 / G4000) Both have AXA tool holdders, the tooling being interchangable, except for height. One AXA is a Shars, the other I don't know. And I'm not going over to the shop to find out. Both holders are wedge type. The AXA is a perfect fit,
for my application. Fitting both machines and being of lower cost for additions. Usually, I do fairly small (<2") work. I commisioned the Craftsman because I got into cutting the disk off of disk brakes. I had a use for the hubs. The disks were too large for the Griz.
The Craftsman may be a "Commercial" version, I honestly don't know. I
was told the "Norton" threading box was only used a couple of years (51-52) on that model. That may be an indicator, for anyone that really cares. I don't.
The studs and T-nuts for both were fitted to the machines. Turning down the solid end to the appropriate size and adjusting the T-nuts to a smooth fit. In neither case do I remember the starting size, just that I had to mill a whisker off the T-nuts that I used to fit just so.
The horizontal mill (Atlas MFC) does not use a tool post
but; I found a source for 3/8 square headed bolts that were a perfect fit to the T-slots, with the exception of being a little shy on the bottom. They were too small to use on one lathe and too large for the other one. I bring it up merely as a reference.
Bill Hudson
