Based on this tread, I decided to purchase some CDCO QCTP Holders, to use with my Phase II QCTP. I purchased 4 ea of the 250-102 and 1 ea 250-101.
Here are some of my observations:
1) CDCO Holders though covered in oil, arrived with surface rust on the Set Screws, requiring cleaning to have them screw in and out smoothly.
2) The finish of the Phase II holders is cleaner/nicer. The CDCO holders have dings and marks on all the surfaces, while the Phase II holders are ding and mark free.
3) The Dimensions, Holder to Holder, are more consistent with the Phase II holders. All the dimensions are with in 0.001" of each other, Holder to Holder. On the CDCO holders the same measurements holder to holder varied by as much as 0.010".
Though, the difference shouldn't effect the performance of the holders, I think is speaks to Manufacturing Controls.
4) Of more importance.... I found on 2 of the 5 holders the bottom surface, where the tool rests (Opposite the set screws) was not square with the bottom of the Holder. I don't have access to a surface plate, so I can measure squareness that way, but I put a square along the back and bottom of the holder, and found it to be square. Measure from the bottom of the holder to the bottom tool surface, I found about 0.0015" difference front to back. Again this shouldn't effect things, but if it were greater, it could start to alter the angles of one's cutters.
5) The Dove Tail and back surface of the Phase II holder were ground
after the black oxide coating was applied. On the CDCO the dove tail was ground before the Black Oxide was applied.
Overall for nearly 1/2 the price of the Phase II, I'd probably purchase them again, unless other's have found higher quality, for a price similar to the CDCO's, with other brands.
Rust on Set Screws of the CDCO
Phase II in the Middle
Phase II in the Middle. It's hard to see in the image, the Phase II holder dovetail and back surface are a smooth Ground Surface. On the CDCO holders, the Black Oxide finish was applied After Grinding. Given Heat is used to create the finish, it would be better to grind the surface after creating the black oxide finish, to reduce any effects from the heating, as with the Phase II
Bottom tool surface not Square. The Picture shows the gap between Jaws of my calipers on the bottom of the holder, as I couldn't get a good picture trying to show it on the bottom of the surface where the tool would sit.
