Erik,
Not sure that you and Bob are talking about the same T nuts.
The two nuts holding the compound to the cross slide are high wear items. Mine were upgraded to grade 8 nuts and bolts. The heads of the bolts had to be machined to fit in the cross slide and slide easily in the round channel. Even though the nuts are never tightened to extreme, grade 8 bolts have closer fitting threads and wear much less.
