I don't know why I had sander in mind. You clearly said G4000. The 17mm dimension made me think of an alternator pulley. Many are 17mm. They are not keyed or set screwed. An alternator on full charge is said to require up to 8 hp to turn. The pulley is just squeezed between a spacer so it clears the housing and a nut and washer on the end of the shaft. The nut is large dia but at 2.5 hp the 1/2 inch nut must be fine for the treadmill motor.
Can a spacer be put on your shaft and the pulley pinched between that and the end nut?
Nice sander/grinder cavebob...!!! Very nicely done.
