You likely have a dent in the shaft from something hitting it, maybe.
By using the high power equipment you have, it really stuck.
First, you need to undo what you have done.
Make a coller to be a cushion, a very close fitting ring or tube that is truly square on both sides, this needs to just fit over the shaft, if it hangs up while sliding from end, file down the cause.
Once it is resting against the bearing, locate a pipe that will fit over the shaft and butt against the cushion and extend past the end of the shaft.
Cap end of pipe.
Do not use a BFH...harbor freight has pneumatic demolition guns, bigger than air chisel, smaller than jack hammer, but do miracles in pounding stuff
Apply lots of oil, then a few pops with the gun, and check for movement.
Once you get it free, look for and repair the high spots.
Use the other bearing as a gage, slide until it stops, inspect for damage, and file smooth.
Sent from my SM-G781V using Tapatalk
