The support hanger assembly pretty much mirrored the quality seen in the universal joints so
had to rig up a replacement. Here's a photo of the so called hanger bearing.....just a ball with a zerc....
Now a pillow block seemed like the way to go so fabricobbled a mount and bolted it to the frame.
It works like a dream now.
My only difficulty was that the shaft was a couple thousandths too big so had to file off a bit of material to
slide on the bearing.
