- Sep 5, 2013
- 3,800
Here's an example of the slotted ring variation that John was referring to (at least as I understood he was referring to anyway).
My lathe came with this one as well as the rocker type, but I think these slotted ones take some of the finickiness away from changing holders. Once the bit is set for centre height in one of the three different depth slots, you can take it in and out without having to obtain centre again. You do lose the capability to adjust rake angle though, so that becomes limited to the particular holder or the grind on the bit itself. I have one set of holders that has a really shallow angle, so I used a largish "donut" to cheat the ring up a little more. It works fine.
I don't use the lantern holder too much any more, mostly a 4-way or 3-way, but I still keep it for the odd occasion when it's the only thing that will fit. I do have a quick change as well but it's not my go to device, mostly because it's a small one and I don't find it as stable as the three or four way blocks. Just the way I'm used to, I guess.
-frank
-frank
