- Jan 11, 2013
- 1,836
Let me get this straight:
-Center drill rod at one end, place against live center in tailstock.
-Hold opposite end in the Three Jaw Chuck.
-turn entire length of rod down to certain diameter (it would help us help you to share these numbers .
-Measure runout - at what part of the work piece?.
If you are NOT turning the whole length of the rod down, there could be runout at the three jaw chuck end for sure.
If you are working with a piece that is already the correct diameter at one end (so you aren't turning that end down), that end needs to either be on a live or dead center, or indicated in place in a four jaw independent chuck.
Lastly, you might want to get a quick look at your live center - I doubt this, but if your center is not working properly or damaged, to the point of .015, you can see it if you pull on the tip sideways or turn it.
Also- live centers require you to have the tailstock exerting pressure toward the headstock end for a live center to stay aligned.
Bernie
Bernie
