- Sep 18, 2014
- 254
Run it on the lowest speed, with some lube. Should do fine.
Was it loud with an annoying thrumming?Guys my machine took way to much time to cut through the steel at 150 RPM, in five minutes i didn't make but a five inch long cut. The cutter was jamming every-time I tried to add a bit more force. I readjusted the belt tightness a couple times and it still jammed. I was using blade lube too. I've given up, I have sheet metal I going to bend.
What feed rates did you try, if feeding by hand this will cause problems unless you are very experienced. I would think .006 or so per revolution of the saw would be a good starting point therefore 150 Revolutions Per Minute / .006 is roughly 1" IPM therefore a 5" long cut should take 5 minutes.
Sometimes machining operations take a good deal of time, I do a recurring lathe job where the roughing lathe work, OD turn for a steady rest takes nearly 1 hour per pass, the part is 65" long, setup time will kill you.Wreck it wasn't loud at all... I kept lubing the cutter and cranking the table at the speed the cutter would take....seemed like forever to make five inches. I have to find a better way, it's to slow.
I just talked to the SIL and told him when the AC/furnace man gets here I'm going to ask him to make a tray for me.... he's a tin knocker by trade and does tin work in his garage.
How are you holding the work? You don't want to clamp in such a way that the slit will tend to close. You could also try pressing a wedge into the slit behind the saw.Guys my machine took way to much time to cut through the steel at 150 RPM, in five minutes i didn't make but a five inch long cut. The cutter was jamming every-time I tried to add a bit more force. I readjusted the belt tightness a couple times and it still jammed. I was using blade lube too. I've given up, I have sheet metal I going to bend.
