- Dec 12, 2016
- 529
I have used a number of different cutoff tools, have had too many scary breaks with the blade style.
If I can get away with it I have been using something like the following GTN-2 clamping holder.
The clamping style has much better retention and is stiffer than the blade GTN holders.
The only issue is the limited DOC, at about 1/2" on the radius. More than that and I head over to the band saw!
The GTN inserts are relatively cheap, and the GTN-2 is maybe 0.080" wide so is easy on the lathe.
