- Feb 27, 2014
- 2,283
I use Fusion360 and Mach3 with no problems. I would try to simplify things such as manually programing some basic X, Y and Z moves and then see that you get what you asked for. If that works, then to the same but using Fusion 360 to generate the GCode. In other words, find a way to isolate each of the components (Fusion360 vs Mach3 vs controller board. I would do this before trying a different CAM system. Remove as many variables as possible and then add them back in, one at a time until you get bad behavior.
