Try not to buy aluminum stock that does not have the mill info printed on it as you will have no idea what alloy or condition it is in, often the material that is available in hardware stores for homeowner use is unmarked and is often 6063. One thing that I have noticed in 30+ years in the machining business is that 6063 structural shapes have sharp corners, commercially available shapes almost always have generous radii at the corners but not always.You suspect right Wreck. It was angle purchased at the local hardware store. My little mill tops out at 1970 rpm and that would be giving her all she's got. I will go up from 1180 and add some cutting fluid. Thanks again!
Thanks, unpleasant would be a better description however, it is frightening in many ways.ImPRESSive drill press you got there
Mark S.
