- Dec 20, 2012
- 9,422
Mikey - What you are describe - the head flying off - is my worst nightmare for this project. When you say pin the head on, do you mean drilling a pin through the side of the head through the portion of the neck inside the head?
Yes, I would use either a roll pin or a solid pin (steel). Roll pins are hardened and are perfect for this job. If you drill a 1/8" hole through the side of the head, right through the part of the handle that fits inside the head, that roll pin will hold the head solidly. If it ever needs to come out you can drive it out with a punch. The roll pin can be ground to length so it fits the width of the head perfectly.
