Around here 3/4 ton pickups go for $200/day. Trailers are $80/day. Plus rigging gear.
You don't particularly need a 3/4 ton pickup, a 2 door F150 ($20/day at Uhaul) will haul 6-7k all day. (I checked, Pleasanton is the same price).
Trailer is $45/day at the Pleasanton, CA Sunbelt:
https://www.sunbeltrentals.com/equipment/detail/1413/0241700/8-9ft-lift-bed-single-axle-trailer-10k/
Roll-a-lift is $75/day near you (cheaper for you than me!).
Note that at Sunbelt, if you rent on a Friday and get it back by Monday at opening, that counts as 1 day! So thats $120 in equipment, plus ~$60-80 in truck rental
) is $200 in rentals + $0.79 per mile on the uhaul.
As for rigging gear, I get tiedown straps at Harbor Freight any time they are on sale, so I end up having a bunch of extras that work great.
I definitely understand if the justification for you is more "I don't want to be responsible if it breaks" and wanting a pro do it, that is reasonable justification. In my case, I was planning on paying more than I paid for the machine, and still couldn't get riggers to be willing to bid the job :/
That said, I was quite surprised at how easy it ended up being. My lathe is big 'ole arn', so its a solid 5k (since it was also full of oil when I bought it, AND has a motor 2x the factory size!), AND I had a bit of an 'uphill' portion.
I was able to bottle jack under the bed (it was forklifted into the trailer) and put it on skates, we had a touch of work getting it out of the trailer (there is a 'texture' to the bed that made the steel wheel'ed skates difficult), but a few ratchet straps as make-shift-come-alongs attached to the floor made quick work of it! After that, it was just the 3 of us pushing it (surprisingly easily!) and making sure we chocked it on the bit of an incline. It took about an hour all told to get it into place.
I've since put feet on it (it didn't come with them, so initially I had it just on the floor), but I haven't had to move it. Those feet above with the built-in-casters seem cool though!
