Hi All -
I have been up and running with a 3 axis setup on my Series 1 Bridgeport for a year or so now and I couldn't imagine going back to my life without it. I'm very impressed with the app, with this forum, and with the support that Yuriy provides!
Most of the time I'm just using the tablet to read position as I work, but on several occasions I have made good use of the linear and angular hole pattern features. I have also been testing the newer feature where you can bring in a drawing and then orient it to the part as a reference ... very cool stuff.
The problem seems to be that every time I attempt to use one of these advanced features things never end up where I am hoping they would go. In other words, if I'm wanting a pattern of holes to move up and to the right they might move down and to the right, or vice-versa. I can usually figure this out with some planning, but I literally never get it right on the first try, which means creating a new workspace to clear the erroneous pattern. The app also doesn't allow the concept of a "negative step", so if you picked the wrong hole to start your pattern from you will be moving the table again to change your start location. I've experimented a bit with swapping individual axes directions and trying some of the features again but if I'm honest, most of my garage time is spent in the late evenings after a long work week and I'm not always firing on all cylinders mentally.![Dejection :dejected: :dejected:](/styles/default/xenforo/smilies/dejection.png)
I currently have my scales set up such that moving the table toward the column is the +y direction and moving the table to the right (when facing the column) is the +x direction. I'm guessing that my convention around the y direction is reversed compared to what most are observing? Is there a default that the app is "expecting" that I would do well to follow?
Thanks!
Lee
Thanks!
Lee
